メインコンテンツにスキップ
MITSUBISHI WD-73C9 rear projection dlp HDTV
25回答 すべてを表示
Replaced Lamp TV shuts down still?
I’m having a problem with my Mitsubishi Lamp replacement, I did a replacement for the Lamp and it went completely smooth nothing broken just the lamp. I did a hard reset and when the tv turns on it stays on for about 30-40 seconds and then shuts down. The Tv also provides me with the 34 error code that the Lamp is bad but I had just replaced it, not also did I replaced it but I cleaned out the dust using an air can and is as clean as could be. Very confused, any ideas??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I have this problem and I see nobody answered you in 2 yrs. Did you ever find the answer?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Luis Esquivel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 36
