iPhone 1st gen. screen suddenly turns off and backlight becomes low
my iphone randomly (it s always charged) turns off and when it does turn on, after about an hour or so (i reboot it by connecting it to itunes and pressing home/turn off button) then it shows everything, but it has no light at all, i have to look really hard to see things. Other times though, when it turns on, screenlight is fine and bright..im so confused..otherwise its in mint condition.
when i got it, looked like LCD panel was damaged, it has a white line on the side of the screen, so maybe i need to change the lcd panel? or change the batteries, or both? please, help.
この質問は役に立ちましたか?
2 件のコメント
and also, i cannot figure out which model it is since it only says iphone in the about section. so im guessing its iphone 1st generation
sofia さんによる
if you look at the back of your iphone and see the bottom 1/3 is made of plastic it is a first generation or 2G, if the entire panel is plastic it is a 3G or 3 GS. you can also get a clue as to the generation by clicking settings/general/about and looking at the model no. a 2G is a1203. knowing which generation will help you decide which parts to buy as they are not interchangeable over the generations...
pollytintop さんによる
