メインコンテンツにスキップ
Amplifiers for home audio systems.
64の回答 すべてを表示
Capacitor replace, original 27000uf 80v replace with 22000uf 105v
Hi
I got a Sherwood AX-9030 amplifier with two big 27000 if 80v caps, which have seen better days. Left channel is lower volume untill the main volume gets turn up and down again.
So, can I replace the 27000uf 80v caps with 22000uf 105v or 33000uf 63v caps? As these are the only ones that will fit (51mm x 105mm).
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Android 修理キット
交換用スクリーンやバッテリーの修理キット
ショップを見る
Android 修理キット
ショップを見る
1 件の回答
選択されたソリューション
Hi @jeppeman ,
It is not wise to replace capacitors with other capacitors that have a lower working voltage rating, as they will blow if their voltage rating is exceeded, so that rules out the 63V capacitor.
Using a higher voltage rated capacitor is OK but if it has less capacitance it will affect the performance.
Here’s a link to a supplier of some capacitors that have the same parameters as yours. Click on the datasheet link next to the one that you want and check its’ dimensions to see if they fit.
この回答は役に立ちましたか?
スコア 2
コメント:
Hi Jay
Thanks for the reply. I'll aim for a replacement part identical to the original. The mouser cap actually fits as per the datasheet, but the size description is on the page is wrong. Thanks a bunch man!
by
コメントを追加
回答を追加する
Jeppe さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 35
