メインコンテンツにスキップ
Appleの2世代目のiPad AirでWi-Fiモデルのみを対象をしています。モデル番号はA1566です。
214回答 すべてを表示
Replace Screen OR Logic Board if images are burned into screen?
So I’ve adjusted the “Accessibility Features” for the discoloration and the burn in. It took care of the color issues, but I still have old images burned in on the screen. We use this for work, and it will be on the same screen the majority of the time that the screen is on.
Should I replace the LCD and digitizer? Or is this a Logic Board replacement? Or something else?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Couldn't tell you unless I had the iPad in front of me and tried another screen myself. To save the trouble of buying another screen with the risk of it having the same thing take it to a reputable repair store to get it fixed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It sounds like a bad lcd to me. iPads are usually pretty resilient to burn in. But as Ben said,taking it somewhere to be repaired would be wise. Then if they replace the screen and it doesn’t work you can possibly get a refund.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
travisabraham さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 117
