メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1231の回答 すべてを表示
Values of SMD components on PS4 SAC-001 motherboard?
Hi All,
This is the first PS4 board I am trying to repair. IT has it’s HDMI port replaced already but they lost some components during the job I guess. There is a component just after the HDMI port, and then one behind it next to a ground pin, then one unrelated in the middle of the board. See pictures. Hopefully someone has an idea of what they are or can measure them (unlikely i know!). And yes, I know a junk board would be ideal, just don’t have one at the moment. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
3件の回答
Are you looking for what components go there? If you like i think i have the same motherboard i am trying to repair on a different issue (No USB) i can take some photos although with a cheap microscope and share those with you in the area you are looking?
この回答は役に立ちましたか?
スコア 0
コメント:
Just saw you answer now , sorry! Thank you for offering to help. I have since gotten another ps4 to repair and I can identify the components using this one. Thank you.
さんによる
Did you ever fix the No USB issue? I have a board with the same thing.
さんによる
コメントを追加
Hi friend, did you manage to fix it? I have the same problem
この回答は役に立ちましたか?
スコア 0
コメント:
I did not end up fixing that board. I stole some filters from it as they break very easily during repair. I have abandoned hope of fixing it due to the horrible job that was previously done on the HDMI port. If you need componenet values let me know and I can check as k have another board
さんによる
thank you very much friend, I need to know the resistance value that is next to the diode on the back of the board
さんによる
コメントを追加
Could someone tell me the value of this resistor? No continuity and no readings. I guess 450°c was a bit too hot for it :D
この回答は役に立ちましたか?
スコア 0
コメント:
Hi Hans,
Could you figure out the value of the resistor? I have the same problem, I tried replacing the HDMI ic and now there is no continuity across that resistor.
I am thinking about buying a working ps4 just so I can compare the values between the faulty board and the known working one.
さんによる
コメントを追加
回答を追加する
Daniel Henderson さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 58
今までの合計 639
