メインコンテンツにスキップ
第三世代の Surface Pro タブレットは、2014年6月20日にリリース。
123回答 すべてを表示
Casing has chipped corner, what can I use to patch it?
Hiya fixers. Attempting to replace a screen on a Surface Pro 3 (1631) and while trying to remove a bend blocking the new screen from going in, a tiny piece of the corner sheared and chipped off! I can now fit the new screen in, but now there is a small section in the corner where the under screen is exposed. It is also quite sharp where it sheared. I plan to file it down enough to where injury will not occur from handling it, but wondered if anyone had an idea of a substance I can use to patch this tiny section. A material that would be malleable at first but then become strong. Last resort I will use a case that covers the corner
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Look up amazon for SUGRU. It’s a malleable putty-like silicone glue which forms a flexible yet reliable glue. I used it to fix a hole in my cars dashboard for example.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe Two Beards さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 42
