メインコンテンツにスキップ
TI-84 Plus calculator support.
37回答 すべてを表示
Zebra lines on TI-84 Plus calculator screen- What can I do to fix?
I don’t know if the TI-84 Plus calculator was dropped, but the screen is 2/3 stripes, therefore the calculator cannot be used. I tried replacing the batteries and a reset.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi, perhaps the ribbon cable connecting the motherboard is partially loose. Just to be sure, I’d like you to run a self test
  1. Turn the calculator on and put it on the home screen
  2. Press [mode]
  3. Press [Alpha]
  4. Press [S] (the ln key)
  5. Press [enter] four times (congratulations, you’re now in the diagnostics section!)
  6. Press [on]
  7. Now your calculator should be displaying different patterns on the screen. Press [enter] to cycle through all 45 or so patterns and contrasts, please tell me if the bottom part of your display works for any of the patterns.
  8. Press [on] multiple times to exit the diagnostics section
If your screen still doesn’t work, I’d suggest looking at a topic on ribbon cable repair which you can find here.
Good luck, please let me know if you have any issues or questions!
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Thank you for your reply! The first pattern of vertical stripes works. The rest of the patterns show white horizontal lines.
さんによる
Yes, that sounds like a loose ribbon cable. Do you have experience with soldering or using a voltmeter? If not and if the cable is just loose, then when you take it apart ( TI-84 Plus Disassembly ) you may be able to get by with just putting pressure on certain parts of the cable (to see which part is loose) then taping (preferably with electrical tape) the loose part back together. Again, I'd suggest following the topic I linked in my original answer if you have the tools. Good luck and I'm happy to answer any questions you may have!
さんによる
コメントを追加
回答を追加する
MaryBeth Booth さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 90
過去 30 日: 401
今までの合計 9,702
