メインコンテンツにスキップ
14" - Core i3 2310M - SUSE Linux Enterprise Desktop 11 - 2 GB RAM - 500 GB HDD
18回答 すべてを表示
My power light is on but my battery light keeps blinking
My laptop fell to the ground and since then I keep seeing my power light on and my battery light blinking. The laptop was charging and was on sleep mode when it fell. Please what should I do.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Does it boot up still?
さんによる
No, it just shows the power light and a constant blinking power light. I have tried hard reset nothing is working. I tried uncoupling the system and cleaning some areas still no show. Switched the ram stick couple of times still nothing. Don't know what to do.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Assuming there is no hardware damage try this:
  • Power off the laptop.
  • Take the battery out. If the battery is integrated and does not have a latch to release it then leave the battery inside the laptop.
  • Disconnected AC adapter from the laptop.
  • Press and hold the power button for at least 15 seconds.
  • Reconnect the battery and plug the AC adapter.
  • Power ON the laptop.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
this solution worked my laptop is ok now thank you
さんによる
コメントを追加
回答を追加する
Esther Ogolo さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 24
今までの合計 2,297
