メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
Trackpad and keyboard stopped working after mojave
Obligatory not my Macbook. Helping someone. Said after he updated to Mojave it was having issues. Now it’s effectively stopped working most likely brought on by the most recent update.
I’ve tried SMC reset, PRAM reset, safe mode, even installed another SSD and did a fresh install.
I’m able to get into the boot menu with the onboard keyboard but after that it’ll stop working. Trackpad doesn’t work at all. Keyboard will let some keys in if you hold them long enough.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Did you accidentally enable “Mouse Keys”?
Here’s a link of what I’m referring to:
https://www.idownloadblog.com/2017/01/23...
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
That's not it. Nothing in accessibility is turned on. I have a different SSD with a fresh install on it. I'm leaning towards hardware related but why would the keyboard work to an extent? If i just type on it like normal it may or may not grab all the inputs but if I hold down the key it'll take it but only on some keys. A will work if I hold it but like N won't work at all.
Everything works on an external mouse and keyboard.
さんによる
@uncommonwater Hmmm.... Have you tried a fresh installation of El Capitan or High Sierra, or any older OS? I would try that just to see. If it works, it works. If it doesn't, it doesn't and we can move from there.
さんによる
@mike_lemke Installed High Sierra and it changed nothing.
さんによる
@uncommonwater Have you tried reseating the keyboard and trackpad cables?
I feel like I've had this issue in the past on a repair I did, but I can't remember how I fixed it now :|
さんによる
@mike_lemke I’ve reseated both of them and did a SMC and NVRAM reset and still same results. Trackpad doesn’t function. Keyboard will take inputs but acts like Slow Keys is on which it isn’t. Same results on 2 different SSDs with different OS. I’m almost down to the point where the cable is deteriorating and causing the problem.
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Taylor Campbell さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 8
今までの合計 958
