メインコンテンツにスキップ
Repair and disassembly guides for Samsung DVD players.
play for some second, then write fan-ng and then stop.
When I plugs my Samsung ,it will play for some second, then write fan-ng and then stop. want can cause it
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
My fan blows normal but still getting the message
さんによる
@Dean Raubach
What is the model number of the player?
A lot of fans have a sensor in them that lets the control board know that they're operating.
If you check the fan connector if it has more than two wires it will have a sensor (usually a hall effect sensor which indicates speed but it could also be another type).
Perhaps the sensor is faulty or the wiring back to the control board
さんによる
My Samsung home theater is intermittently going off, and display 'fan chk on the screen '.
Please might be the problem.
Afterwards, I removed the fan from the mother board, and still doing same.
Thank you
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi @ afriday96,
What is the model number of your Samsung DVD player?
fan-ng most probably means "fan no good",
First check that the fan’s air vent is not blocked or obstructed by dust.
If it is clear check that the fan is working (assuming your player has a fan-you don't state the model number).
If it isn't working, check with an Ohmmeter that the fan motor is OK. Do this with the power disconnected from the unit and the fan disconnected from the motherboard.
If the fan motor is OK then you’ll have to check if there is power being applied to the fan motor when the unit is powered on.
このアンサーは役に立ちましたか?
スコア 5
9 件のコメント:
Thank you so much is working now
さんによる
Thank you so much 😘😘❤️❤️. Is working now
さんによる
I am having the same problem. I have blown dust away. But still not working. I can't take the lid off my samsung blu ray. Took 2 screws out of back, but still firmly shut
さんによる
@g3rl2gkcboqezhg
What is the model number of the BluRay player?
さんによる
さんによる
4件以上のコメントを表示
コメントを追加
@jayeff is Samsung series 5 (HT-D5550W)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@lilbenz
I realize that and answered you 2 days ago.
Click on "4 more comments" in the Chosen Solution above to see my comment
さんによる
コメントを追加
回答を追加する
afriday96 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 70
今までの合計 11,829
