Did this break off
I was repair my iphone cause it had waterdamage. And i used a toothbrush to clean up these connectors. But i’m affraid i broke something
off.
この質問は役に立ちましたか?
off.
この質問は役に立ちましたか?
Those two “gold” points are test points, specifically PP_CPU on the right of the image and PP_GPU on the left. Nothing was soldered there before.
このアンサーは役に立ちましたか?
Thank you so much is was so scared.
No, those pads on the board have no solder on them, indicating there was never a component there. However, once the logic board has been exposed to water, it can’t be repaired by cleaning.
このアンサーは役に立ちましたか?
I tried cleaning it with icepropyl alchol but after putting annew battery in the device it didn’t work.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 42
