Why won’t my iMac fully boot?
My iMac will come on with the Apple logo a spinning wheel and a loading bar. The bar takes around 30 minutes to fill and once it finally finishes the wheel keeps spinning for a couple seconds and then the whole thing shuts down and I have to start again. What do I do? Also when I was trying to work on it I accidentally screwed up something and now the lcd has a red/pink color. Any idea what that could be?
edit: Apple told me the first problem is a hardware problem but I’m not sure what the problem is because I haven’t been able to run diagnostic and I can’t install Mac OS on a new hdd. I think the cd drive might be bad not sure tho.
Are you able to get into Safe Mode? Press and hold the Shift (⇧) key when you reboot.
Reference: Mac startup key combinations
Dan さんによる
When I hold shift it does the same thing as before.
Isaac さんによる
@mrcrazy - Lets try this try booting up in Target Disk Mode holding the T key. Does that work? You should see a FireWire Icon on the screen.
Dan さんによる
Same issue with me !!
JackJohn77 さんによる
