メインコンテンツにスキップ
Repair guides and support for Kenmore washing machines.
1861回答 すべてを表示
Washer won't drain during wash cycle, but will drain for drain cycle
Hi I have a Kenmore Elite 79629272001. Manual here:
https://www.searspartsdirect.com/manual/...
Kind of going crazy trying to fix it! It leaks during the wash cycle, and I’ve already replaced the drain hoses. Thing is, the pump is working fine - it drains when I put it on the “drain and spin” option just fine. But DOESN’T drain during the wash cycle. I think the water is overflowing in the tub, and it somehow isn’t signaling to the pump to pump? Know what I should replace or what to look for?
Note: it spins during all cycles just fine.
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Hi @needawasherpls ,
On the wash cycle, does the water stop filling the tub before the wash action starts or does it continue to fill whilst it is agitating?
Does it drain OK at the end of the wash cycle?
Does the control knob step around from the wash cycle to the rinse cycle OK?
Thing is that it shouldn't drain during the wash cycle it should be washing in the water that's in there, but it should drain at the end of the wash cycle so that it can refill to the selected level with clean water for the rinse cycle.
Does it also continue to fill during the rinse cycle?
If the water continues to fill during the wash cycle and the rinse cycle there may be a problem with the water level pressure sensor which tells the machine to turn off the water when the selected level is reached.
Is there water in the tub in the morning before you start to wash the laundry?
If so you may have a leaking water inlet solenoid in the machine which may continue to fill the machine when it should be closed.
さんによる
Washing machine drains fine on spin cycle and not wash cycle
さんによる
@Carl Wimble
What is the model number of the washer?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Make sure you’re using the correct type (HE) and amount of detergent, as something as simple as this can create problems for these machines. Using too much or the wrong type just might be making too much suds. If you’re uncertain, just look in your owners manual and follow their instructions about this. This is a simple and inexpensive fix, if it turns out to be the problem.
If the machine drains and spins properly at the end of the rinse cycle it tells you that the electrical circuitry and mechanical parts required for draining and spinning are all working just fine. This means your problem is something different, and exclusive to some failure or dynamic occurring and interfering only during or at the end of the wash cycle.
Comparing the two cycles, everything is virtually the same - (abbreviated and simplified) inlet valve opens, water comes in until level switch detects enough water, inlet valve closes, slight delay, then agitator starts & runs until timed agitation cycle completes, slight delay, drive motor starts, engages pump, draining begins, brake releases, and spinning begins. One difference in the two cycles is the use of laundry products (No suds issue to possibly interfere during the rinse cycle, for one thing).
The only other thing I can think of as possibly the problem would be an issue with the control board, in which case your only option would be to replace it. This is an easy repair, but an expensive part. Good Luck!!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you, I was thinking that too, that if it works after rinse it's probably not a "mechanical" problem. I'll look for the part and try and fix it myself if it's cheaper than the hassle of moving in a used and unknown machine.
さんによる
コメントを追加
回答を追加する
Jasmine Bond-Cavanagh さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 68
今までの合計 5,425
