メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Wifi grayed out, bluetooth not connecting
So, a few months ago, at some update, i dont think it was later than ios 12, my wifi and bluetooth died on me… the issues is as following:
-wifi is completely grayed out, can’t toggle it form control center nor the wifi menu.
-bluetooth can be toggled but it just… load? and thats all.
Now i’m on ios 12.1.3. already tried multiple versions of ios, even betas, i stopped updating in the hope i might fix it with jailbreak but i missed the jb train and now i’m going for a week in another country where there is no roaming and cant use the phone since i have no wifi.
And now my question is…. is it software related or the chip died?
The phone model is MN8X2RM/A
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Wifi chip has gone faulty, there really isn't a way to fix it without going through a lot of re-work on the phone, which I don't recommend as it is really expensive ($200+)
This is pretty lengthy but here is the process in general for a wifi chip replacement:
What needs to be done is the wifi / bt chip combo would need to be replaced on the board via a reputable experienced micro-soldering technician. Then since the replacement chip has a different MAC address identifier the memory chip which is like the hard drive will need to be reprogrammed with that new same Mac address in order to get the phone working with the new wifi chip.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
ow, i forgot to mention…. when i got the phone, it wasnt brand new. the previous owner replaced the battery. could it be just a faulty connection? i will take the phone into a service and check, if not… i will sell it for scraps
さんによる
For the Wi-Fi / BT chip most likely not as greyed out would mean a hardware fault caused by that chip going bad. Not connected / damaged antennas would cause very bad or no reception on Wi-Fi, bluetooth and/or cellular 3g / 4g.
さんによる
コメントを追加
回答を追加する
Mircea Togerescu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 647
