Recommendation for an adhesive that doesn't instantly bond?
I am planning on mounting a new 13” LCD panel on a Mid 2014 MBP.
From what I’ve read and seen, you must execute several steps in exact order. If you skip any of them inadvertently, or misalign the panel, you must correct the problem by unmounting the panel. This is the only part of the procedure that terrifies me most as it poses a high risk of cracking an expensive panel.
Are there any double-sided tapes or adhesives available for mounting the LCD which doesn’t instantly form a high strength bond, giving you the ability to align or remove the LCD more easily, if needed?
この質問は役に立ちましたか?
