メインコンテンツにスキップ
Released in April 2011, the D5100 replaces the D5000 as one of Nikon's popular consumer DSLR cameras. It features a replaceable Nikon F-mount lens.
53回答 すべてを表示
締切られた回答
Who actually did the D5100 teardown (pls answer in 1st person)
Is there a way to achieve direct dialog/correspondence with the specific individual who actually removed the rear cover in the D5100 tear-down ?
i have questions only he/she can answer
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
To find who worked on a project, go to the teardown, (in your case, here: Nikon D5100 Teardown)
See the picture in the upper right hand corner. Above it there is a link to its History. Click on that link. You will see that this was a joint effort by Walter Galan, Miroslav Djuric and Andrew Bookholt. You can see each change as it took place. Compare the step you are looking at to who did it and then click on their name.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Very complete answer. +
さんによる
コメントを追加
Many thanks Sir !!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,216
