メインコンテンツにスキップ
Galaxy S7 Edgeは Samsungの2016年最新モデルGalaxy S7のスクリーンがカーブしたデザインです。2016年2月に発表、同年3月11日に発売されました。モデル番号はSM-G935です。
329回答 すべてを表示
S7 edge has service after repair, cannot make or receive calls.
Hello, I just replaced the screen (and frame assembly) of this s7 egde, and everything seems to be working fine, however, I cannot make or receive calls. When I try to call, the phone app shows dialing for a second and then shuts off, and when I try to call the phone, it goes straight to voicemail. I do however get LTE data and can send out and receive text messages, oddly. Any help would be much appreciated. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Did you replace the screen lcd that comes with the mid frame or did you buy them separately? I am in the process of doing a replacement of the whole phone, and noticed that the new mid frame seems to be missing the tiny square contact points that coincides with the motherboard. The old one has them.
さんによる
コメントを追加
1 件の回答
there are couple of reasons for this. one might be your antenna cables are not on properly. the signal antenna is connects from your SUB PBA (daughter board) to your main PBA board. another problem which I think might apply to you if you changed the frame to a new one is that the frame has RF(radio frequency) issues. you would have to replace the frame. when getting a new frame, it is best to get a refurbished OEM frame than getting a copy one as you won’t be able to find OEM brand new frame in the market.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Armen Orbelyan さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 47
