Why no lights?
No, Apple logo light, No keyboard light and no display light. Can anybody help
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Have you tried an external monitor? If you have video with the external monitor the likely problem is the LCD cable or the LCD itself. If you don't then you may have a logic board problem. Ralph
このアンサーは役に立ちましたか?
It sounds like it is booting, but cant see anything on the display. The power on LED is the only light.
このアンサーは役に立ちましたか?
If you hold a flashlight up to the display can you see any faint graphics at all?
I cant see anything on the display. I wouldnt think the LCD monitor cable would have anything to do with the keyboard backlight, but I could be wrong.
このアンサーは役に立ちましたか?
Could still be a bad battery, or bad pram battery, you may want to try resetting your SMU. and it may not be a bad logic board, could just be bad dc-in
このアンサーは役に立ちましたか?
I can see the apple logo very faintly on the screen. Tried a reset and no luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,160
2 件のコメント
brian さんによる
brian さんによる
