Can't tun-on. I can't turn-on my laptop. it's not the power.
can you help me please, my laptop not turn-on there are 3months ago. I check the serial on HP and I see STATUT: EXPIRED. whats wrong with my laptop and what I can do to turn-on ?
Once your build reaches the license expiration date, your computer will automatically reboot approximately every 3 hours. As a result of this, any unsaved data or files you may be working on, will be lost.
The computer will no longer boot, 2 weeks after the license has expired. After the expiration date is crossed, when you start your computer, you will see a Recovery message – Your PC/Device needs to be repaired message. You will not be able to log in to your computer. In this case, you will have to download the ISO file from another computer and then transfer the ISO file to some installation media. Once you have done this, you will have to boot the computer from the installation media to install the latest build of Windows 10.
You should always backup all your data and check your Windows Update to see if any new build or upgrades are available.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 66
Hi Farid
What issues are you experiencing?
no power or response when pressing the power button?
had you checked on your power adapter if it is giving out correct voltages?
Augustine さんによる
