メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
623回答 すべてを表示
NFC quit working after charge port replacement
I work for a local phone repair shop. Me devices don’t come back with issues after a repair. However, after changing my charge port, my nfc is no longer working. No Apple Pay and I can read my wife’s Freestyle constant glucose monitoring device. I have checked all connection an found nothing wrong. I have also done a factory restart to no avail. Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
最も参考になった回答
Pay close attention when removing the logic board on the 8+. The NFC portion of the logic board is located on the top right hand corner. The stand-off screw, just below the the one holding down the camera shield, also has a black plastic ring that it goes through. When you replace the logic board make sure that ring is on top of the logic board and not underneath it. If not paying close attention you will miss this. That ring is part of a short connector that wraps around the cameras to the top right hand corner of the frame. The NFC uses the frame as an antenna. Apple Pay will not work if this step is missed, nor will anything using NFC.
このアンサーは役に立ちましたか?
スコア 5
2 件のコメント:
This worked! Thank you so much for sharing your wisdom. God bless you (:
さんによる
very helpful! Thanks!
さんによる
コメントを追加
回答を追加する
Darin Barfield さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 8
今までの合計 765
