Stuck on apple logo, now fully shorted
<- do you think this micro crack can be the issue ?
Hi,
I´ve got iphone 7 plus which was stuck on apple logo, power consumption was 0.80a and occasionaly jumped to 1.5a for a split second.
I left it like that for 2 minutes to see if it will eventualy boot up.
Unfortunately phone died and went to the full short after that and PMIC is extremely hot .
Should this cause PMIC to fail or most probably that is some cap shorted anywhere else without the heat coming out of it ?
I want to make sure before I pull anything from the board.
thanks
この質問は役に立ちましたか?
1件のコメント
We will need more info. You say it went to full short. Did you determine this from your ammeter? First diode mode VDD_Main or hook up a dc power supply and see if it is drawing current before prompt to boot. If it is a VDD_Main short I doubt it would be the PMIC it could be a capacitor or IC. Just because something gets hot doesn’t mean it has a short to ground.
Chris Stables さんによる
