Why is my cruise control works only sometimes and sometimes shut down
I checked all the fuses but I still can't find the problem
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
This is usually caused by the cruise control brake switch. Where safe but with car on the road with cruise dropping out, can you set cruise and keep it running by lifting the brake pedal up towards you? If so, then look at the brake pedal switch and locate and adjust the position of the switch slightly so that it does not disengage prematurely.
コメント:
I have check that switch over and over I cant find anything wrong with it. Thanks
Kenneth Camper さんによる
When cruise is set it doesnt ever disengage
Guess you have know more answers. Thank
I had a mechanic check my car once for abs problems and apparently that made the cruise work more often but it still does have some problems so i think the problem is connected to brakes but not in the pedal, somewhere else
Damanjeet Singh さんによる
過去 24時間: 6
過去 7 日: 21
過去 30 日: 83
今までの合計 1,336
On the 2013 the cruise control works great for days when it wants to. And sometimes you can push thr button a 100 times before it works and other times it wont work at all
