メインコンテンツにスキップ
From the Inspiron series 15 model 5558 released in 2015 by Dell. A mid-level laptop with a 15.6-inch display and fifth generation Intel processor.
17回答 すべてを表示
My laptop don't give display on windows
my laptop fell from my lap once, from that day when ever i press my start button it dont give display of dual boot menu, after far while its automaticaly boots into linux and start giving display,
no display during starting logo time+boot menu+booting into window
gives display on linux only , and gives full display on hdmi also
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Check BIOS settings for default display.
Resetting the System Setup (BIOS) to its Default Settings
  1. Reboot the computer.
  2. When you see the Dell logo during POST, press the <F2> key to enter the setup screen.
  3. On the System Setup screen, click Load Defaults.
  4. Confirm to load the defaults.
I am aware that his edit is a “bit” late for Irtaza but may be helpful for others.
First download and save the pdf Dell Service Manual:
https://dl.dell.com/topicspdf/inspiron-1...
This will also show you how to disconnect the CMOS/BIOS coin battery for a complete reset. Remember to unplug charger/pwoer supply and remove main laptop battery before openning up case. Remove or disconnect coin battery, press power button for 15 seconds and reassemble.
Then run the DELL diagnostics:
https://www.dell.com/support/home/en-nz/...
to identify any possible obvious hardware defect. This could avoid wasting time.
Windows 10 two most common problems, in my experience, is not booting up correctly and corrupted video drivers - which can be very subtle. So clearly this is a driver issue in this case. What I do in this situation is completely remove all trace of video drivers. My favourite tool is freeware Display Driver Uninstaller (DDU). https://www.wagnardsoft.com/
What it does is remove all traces of the current drive - folders, inf files, registry, etc. The result is that Windows boots into that generic VGA driver (Safe Mode uses this). Make sure you have the latest video drivers downloaded and ready. There are two. Which is yours?
  1. nVIDIA GeForce GTX and Quadro Graphics Driver 20 Jun 2019
  2. Intel HD Graphics Driver 23 Apr 2018
Also make sure the BIOS is upgraded to the latest:
This Microsoft page may help the understanding but DO use DDU.
https://support.microsoft.com/en-us/topi...
You should be good after reinstalling the latest graphics/video driver.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
done , still the same problem
さんによる
コメントを追加
Irtaza Raja  if it displays on the laptops LCD screen in Linux but not Windows it will be your Windows OS that has issues. The HDMI display is a good sign as well since you know that your GPU circuitry etc. is all working as should. Try a new Windows install. Of course you did not say that it displays on the laptop LCD. So if you are using an external monitor for all OS’s then there is the possibility that this is your screen.
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
already tried installing windows again , but same results
thanks oldturkey03
さんによる
So it displays Linux on the computers LCD?
さんによる
yes linux runs fine on laptop lcd
さんによる
It cannot be a hardware issue since it does work with a different OS. What happens when you do a complete reinstall of windows?
さんによる
same results, just changed little bit.. like now when i press my power button it starts beep beep ... so if i have to use linux i have to connect hdmi and than press the the power button it runs fine on hdmi when its boots into linux i unplug the hdmi and laptop display work fine than.. n right now i am reply using linux without hdmi ,
same Technic is not useful on window, it works fine in hdmi mode but when i unplug the hdmi screen doesn't turn on ..
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Irtaza Raja さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 22
今までの合計 214
