iPhone stuck on "waiting for iPhone" when trying to restore from DFU
I have a dead iphone. Managed the charge the iPhone externally, and itunes detects it in DFU mode, but the screen stays black. When I try to restore, it gets stuck on "waiting for iPhone". Eventually getting error 4014 when unplugging.
I have also tried flashing with 3uTools, but i get to 11% and "ERROR: Unable to switch DFU mode to Recovery Mode."
Any advice? Thanks.
この質問は役に立ちましたか?
2 件のコメント
I have the same problem and now I have fixed it, it’s due to NAND ic , if the phone didn’t entered in recover mode by pressing the volume down button then its dead sure due to NAND ic, so just reball the NAND and your cell phone be OK, but it’s need level 4 experience to reball tha NAND , if you are inexperienced then plz don’t attempt.
Muhammad Muddassar Rafique さんによる
I had a seeming problem, I only entered DFU and when it was time to change to recovery, I did not try to change many cables to usb ports and there was no case. I opened it after so many attempts and discovered the disconnected battery. I plugged it in and then I could flash. The comment is for someone who will experience the same in 2021
Omar Ramos さんによる
