Where is the GSM Hardware on iPhone 6 plus?
I have to replace a Verizon logic board with this logic board that is locked to AT&T carrier.
My question is where is the CDMA or GSM Hardware on iPhone 6 plus?
I’m asking this because I use a Verizon Sim card. I know Verizon use GSM. If the GSM “Hardware is on the motherboard” then I don’t have a GSM reception when I unlock my AT&T Iphone.
If the “CDMA“ or “GSM” hardware is on the Logic Board, then I should not unlock this AT&T phone. However, if the network is somewhere not on the Logic board, then I still have good GSM connection because I didn’t touch the GSM part.
この質問は役に立ちましたか?
1件のコメント
All of the iPhones use a logic board which holds all of the circuity there is no 2nd board which holds the CDMA or GSM circuity.
An iPhone which is carrier locked likely still has a payment contract on it (or never had it unlocked after the final payment). I would contact the carrier to see if you can get the phone unlocked. At least then you can sell it.
As for CDMA or GSM compatibility. The radios are fixed to the given phone needed by that given carriers cellular system. I would recommend you locate your phones supported bands looking it up here Every iPhone. Then you can figure out what carrier you can use your iPhone as is.
If you still have questions give us your exact model.
Dan さんによる
