Repair guides for the Kenmore 80 Series of washing machines, manufactured by Kenmore.
David christman @dchristman
評価: 1
投稿日: 2019年5月30日
Washer doesn’t fill up on regular cycle but does fine on bedding cycle.
この質問は役に立ちましたか?
mayer @mayer
評価: 685.3千
MacHale Enterprises
3.4千
1.1千
2.6千
My estimate is that the two cycles run at different water temperatures. Try. if you can, to set both cycles to either fully hot or fully cold and see which works, then you will know which side to go look at.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 64
