Where can I find if this iMac has a replaceable GPU
Hi,
My iMac's model is A1312-100 EMC: 2374.
Where can I find if this iMac has a replaceable GPU?
Thanks on advance
Your system is one of these EveryMac - EMC 2374
Here’s the procedure to replace your GPU MXM board: iMac Intel 27インチ EMC 2374のAMD Radeon HD 4850ビデオカードの交換
And here are the MXM boards the system came with:
You’ll need to clean off the thermal paste and apply a fresh coat and the VRAM chips thermal pads will need to be replaced as well. I do this even if I get a replacement unit with a heat sink attached.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 74
