メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
Fan connector contacts pulled off, anyway of not spending 1100$
I pulled the FDC clip contacts 3 of them right off the board, this is not the logic board I see for sale and that repair shops think I'm talking about. There has to be another way of connecting the fans flexy cable to it's required +\- signal and so forth, could I just jumper it to the other fan? They want 1100$ for this, not a chance its not the board with the processors and so on its on a board you can see when the logic board is taken out. the computer was 3grand Canadian im not gonna believe that price when its not the main logic board, someone spoke of finding potential contacts with there multi meter and hooking the fan up, he stated it was doable because they use PWM. Any help would be amazing
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Can you post some pics of each connector so we can see the damage. Need both the broken off connector so we can see the contacts and the locations on the logic board. iFixitでの質問に画像を追加する方法
さんによる
Here are some more pics please comment if these are not suffice, #dan #arbaman and everyone else who are taking the time to help me, I will be more timely answering from here on, I appreciate this very much
さんによる
What I see is, at least for me, not enough to say if what is left there is sufficient for resoldering the connector in place, would need a view with a microscope and maybe even that might not suffice. Have a look at the answer from @oldturkey03 and relative comments, you'll likely need to test the working connector to get reference values in Ohms and in diode mode and see if you can find the same where the pads were lifted. Maybe one could do some long jumpers with enameled copper wire getting the missing circuits from the working connector. One should try and see, but in any case it's a bit of a demanding repair given the small scale. I believe there's not much else that can be recommended besides what it was already answered.
さんによる
コメントを追加
3件の回答
ベストアンサー
@meticulous @arbaman take a look at the schematic. Looks like it only uses 2 of the 5 pins
@meticulous post another image but zoom out so I can see the orientation of the contacts etc. Getting old and can’t see very well ;-)
Update (05/28/2019)
@arbaman @danj here is the fan connector etc. What do you think
このアンサーは役に立ちましたか?
スコア 2
9 件のコメント:
Good catch OT!
So we really only need to worry about the middle pin (ground) as pin 1 is still viable!
さんによる
Don't you find it a bit strange there's just one power line there ? I wonder who takes care of the fan speed..
さんによる
I don't have the schematic to check so its quite possible it only need two lines. @oldturkey03 will need to check.
さんによる
@arbaman @danj I'll get back to you on that one as soon as I get done with my real job :-)
さんによる
@oldturkey03 - The circuit looks a bit disjointed.
Where does FAN_LT_TACH or the FAN_LT_PWM (and RT lines) goto?
Where does PP5V_S0 link into?
I see PP3V3_S0 LEFT connects to U6000 VDD & VDD_IO via R6013 as well as CS via R6010 but where's PP3V3_SO RIGHT connect? Is there a second chip?
さんによる
4件以上のコメントを表示
コメントを追加
最も参考になった回答
Technically what you have in mind could be done but it’s going to require precision and fine tools. I don’t have a schematic for that board and although picture is good, magnification is not enough to give a clear answer. Two pads could probably be recreated by lightly scratching the adjacent surface enamel and make a jumper with copper wire. I can’t really tell where the central one of the three lifted pads should go but a microscope should probably give an answer.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Really need to see what the connector its self looks like and a much clearer zoomed in picture of the pads to see if this is salvable.
Do you have a fine tip soldering iron as well as a hot air station or have a friend who does?
さんによる
@oldturkey03 - Didn't he leave the hot air stations in his will ;-}
さんによる
@danj @oldturkey03 LMBO, starting my afternoon work with a laugh :))
さんによる
コメントを追加
It is a bit hard to say for sure, given the picture is not clear enough, but I believe a microsoldering tech can scratch and find a nub of the trace.
Then it would be possible to tin that nub, and jumper the fan cable to it directly, altogether skipping the connector.
Heat should be used very conservatively to avoid damaging the keyboard.
I would do it this way myself and charge less than the cost of replacing he keyboard (your second option) or your whole top case (your third option).
To say for sure that this is feasible would require the device to be on my bench.
So my advice to you is to find a reputed microsoldering tech near you, and let her/him have a look and quote you a price.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Jeremy Murphy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 394
