メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
締切られた回答
Screen won't turn on but iTunes recognizes the phone
Originally phone was dropped and landed on the power button which is now hard to press. But did a tear down and checked all the connections. After reassembly, when plugged in iTunes recognizes the phone, but the display is completely black. Any ideas on why the phone would be recognized, but no screen?
Update
Checked all the connections. All were tightly seated. Now iTunes won't recognize phone at all, which I assume means the phone is not turning on. May have to take it to a repair shop as it seems there is more going on than just the LCD screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Also check if iphone may be set to DFU mode
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It will most likely be a loose LCD connection. Either that or you have damaged the connections during the tear down. Try taking off the metal plate on top of the LCD and Digitiser connections and re-sit both connectors. Also look at the copper strips inside both the connection and connectors to see if any are missing. Write back with what you have found and we will go from there :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 5,840
