メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
558の回答 すべて表示
Need help on water damaged SSD
Hello guys,
My early 2015 13” MacBook Pro recently just went through water damage. Turns out everything is fine except my SSD [MZ-JPV2560/0A3].
I took my SSD to couple independent data recovery firm (which all have good reviews), both told me there is a high possibility of main control chip being broken.
One refused to do it because it is too risky with very low recover rate. The other one did performed a chip-swap but failed. They took some components out and glued back again.
I am attaching the picture of my SSD as well.
is there any possible way to extract data from my failed SSD? or it is completely gone?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
2回答
最も参考になった回答
If data recovery centres were unable to extract data off the chips then there's no way to get it off. Basically think of it as the chips are fried from liquid damage.
この回答は役に立ちましたか?
スコア 2
コメント:
I've tried figuring out what does what on those blade drives but without basic schematics seems to be a mission impossible and I couldn't find them anywhere. Hope the condition shown in the picture is not how the drive was given back to the OP.
による
コメントを追加
It does not look like the SSD was touched!
I don’t see any damage and the board and chips coating appears to be intact! So I don’t think they did anything to your SSD either.
I would get the needed USB case to hold the SSD and then connect it up to another Mac which is running MacOS Mojave (as I’m suspecting your drive is running APFS). Lets give Disk Utility a try again and if that still can’t see your SSD we’ll need to try a 3rd party app Drive Genius 5 see if the demo will see your drive.
この回答は役に立ちましたか?
スコア 1
コメント:
I already tried using USB case. There is current passing through the case and SSD, but the SSD is not recognized in computer.
による
Who's case did you use? So Disk Utility didn't show anything at all? Did Drive Genius work?
による
コメントを追加
回答を追加する
_ryansean さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 26
今までの合計 51
