メインコンテンツにスキップ
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218回答 すべてを表示
Screen messed up after isopropyl alcohol. Fixable?
So after I cleaned the board with isopropyl alcohol after some water damage but I cleaned some metal parts off the screen because there was some corrosion. After I did that the phone now starts up but the screen now looks like this now. Is this fixable or is it permanently going to be like this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You have moisture in between the diffuser layers of the backlight. You're probably looking at a screen replacement or at least if you have the tools and skills a backlight replacement. It looks like a replacement screen assembly is only about $30 with the frame so that probably your best option as long as your confident the phone will work still after the water damage repair.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jimmysofat6864 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 185
