メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
Is this more than a cable fix?
A friend is asking. The screen is AWFUL diagonal lines and a black thing in the middle. Picture attached. I’m wondering if this is a cable problem and might actually be fixable.
? Don’t know how to search for the info I might need. It’s also missing the actual glass Apple logo on the case - looks like it was broken. Could that be part of the issue? Thanks for help.
External monitor attached through lighteneing port.. Any help in diagnosing?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
A bit more information. I plugged it into a external monitor with lightening port and got a colorful but hazy screen of a random shapes. (I'd post but don't see how.)
さんによる
The internal display image is telling me something very heavy sat or was dropped on the lid crushing the Apple logo into the LCD screen cracking it. So that will need to be replaced.
The second image of the external display is telling me the logic board also got damaged too! So the bottom cover must have also punched into the logic board as well.
さんによる
Something dropped on it makes sense. It was the computer of a young adult, her father asked me to look into it.
So at minimum there is a $500 item (Display assembly) and there might be a logic board also. ~$350. I’d say that this computer won’t get fixed. But I’ll keep it around. I have the same computer (as it happens) - Maybe I can use parts from it at some point. Thanks for helping!
I think I’m going to get one of those sleeves for my own computer! This is a nasty reminder of what can happen by accident.
さんによる
コメントを追加
1 件の回答
ベストアンサー
The external looks fine. If that was bad, it would show a similar defect or nothing on the screen. The display is set to extend rather then mirror, so that will need to be changed.
The internal LCD is broken and needs to be replaced. rMBP screens are best replaced as an assembly since the layers are part of the assembly unless you know how to do it consistently - almost nobody does.
Refer to this guide to see how to replace it.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
@nick - The external displays image is telling me their is more of a problem than just the display ;-{
さんによる
It looked like the owner had something that blurs the background up to me :P.
さんによる
コメントを追加
回答を追加する
Annamarie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 216
