iPod does not come on at all.
My iPod does not come on. When I plug the charger in, The screen comes on for a second, then it gets really hot.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you iPod still has the original factory battery, I would recommend replacing the battery first to see if that solves any issue. My first inclination would be to assume a bad logic board, but the battery is certainly a cheaper and possible fix. What is the model number printed on the back of your iPod?
このアンサーは役に立ちましたか?
I would second everything Brady Cabe said-- try replacing the battery, but if that doesn't help, it's likely a bad motherboard.
yes, brady sounds right
There are two sources for the heat. One, the battery heats up while charging, two if the hard drive is constantly spinning it will heat up. Can you hear the hard drive spin up when you plug it in?
このアンサーは役に立ちましたか?
Did someone edit out the heat question?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,153
