iPhone 6s wont power On
HI everyone,
Hi @refectio SIR
I have an iPhone 6s (no water damage) with Vcc main Short.I find the short capacitor c2330 with Freeze Spray and short gone away.
I try to turn one the phone, DCPS show 0,01 to 0,07 amps, and phone doesn’t turn on.
I tro to change tristar and tigris but the problem is same.
Nand voltages are ok
The strange thing is : when I connect USB cable, I have 5 volt on PP5V USB RAIL and also in TIGRIS PMID RAIL.
The capacitor are not connected between them, if I test with multimeter.
I put out the IC and check the voltage under IC ON F5 PAD, The voltage is ZERO.
And regularlay have 5 volt on VBUS PADS, but when put the ic the voltage came back on TIGRIS PMID rail.
Any suggestion guys?
Thanks and sorry for my bad English.
この質問は役に立ちましたか?
