メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
327回答 すべてを表示
Can MBP (2017 / touch-bar)'s battery be replaced without losing data?
Can MacBook Pro 2017 (15-inch / with touch-bar)’s battery be replaced without losing data?
I've heard that battery is combined into top-case which includes CPU, memory and SSD.
I have some trouble only with battery, but I wonder is it fixable without losing data?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
In summary, without knowing the symptoms, we will assume that your diagnostic is correct, that the battery is bad, in which case you can replace your battery or top case without losing your data.
The long answer:
The mother board has on it the CPU and storage (SSD). The battery is glued to the top case which is independent from the mother board.
The top case can be replaced entirely, or you can replace just the battery (takes mores skill and time, saves money). Follow this link to learn how, and what tools to use.
This, of course, assuming the battery is really bad since at 2 years of age, they should rarely fail; detailed symptoms can help validate battery failure as sometimes other issues on the board can prevent the battery from charging, and/or the charger itself can be bad.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thank you so much for your answer!!
I just sent it to a repair shop now, and I was told that It's surely the problem about battery but it need to replace "top-case".
This is perfect answer for me because I wondered whether "top-case" is independent or not.
Thanks for helping me out. I really appreciate that!
さんによる
コメントを追加
回答を追加する
nick jonas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 347
