メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
締切られた回答
Lock button clicks but doesn't work
IPhone 3G on off lock button switch clicks but doesn't do anything. It wont sleep or power off so reseting it isn't an option. So how else can it be powered down/sleep? it was dropped so bad that the metal frame is coming undone from the back casing, you could probably pry it open from that corner. What do I need to do to get the lock button working again? Seems to me that something either came undone or possibly disconnected inside? Again it clicks and looks like it should work so it must be inside. Doesn't seem like I need to replace the button at all but not sure how to fix this. Please Help Please?!!!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
Pinching it doesn't do anything either could something of gotten lose inside? Ive never tried fixing this so nit to sure about how to go about getting to it I mean i can get the screen off but thats about it. so what should I do what would you do to try and fix this?
さんによる
also since i cant power it down should i wait till it dies before i open it?
さんによる
It is always good repair habit to turn OFF device before repair work. The 3g seems to be less vulnerable to device failure during repair when ON compared to 3GS. If you want to turn your iPhone OFF, you can use program TinyUmbrella to turn it OFF. Open TinyUmbrella connect iPhone to computer, click on the iPhone name, click Enter Recovery button, this will put iPhone into Recovery Mode, unplug iPhone wait 30 seconds it will turn OFF. Only way to Exit Recovery when you are done with the Repair is to use TinyUmbrella, connect iPhone let it turn on, if still in Recovery Mode, click iPhone name, click Exit Recovery button.
さんによる
when your getting to the lock button after opening up the phone is it necessary to disconnect cables 4, 5, 6? why is this? when i opened up the phone it was super dirty it looks like tiny tiny shards of cardboard or something should I clean it? what should i use? thanks to all the responses
さんによる
コメントを追加
2件の回答
最も参考になった回答
Pinch that top corner front glass to back case together, and push power button. If it works there is chance that carefully super gluing this corner back together could help.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Take an injector, add some super glue in it. Then use it to glue the Bezel to the back cover. Make sure you do it slowly and in Maximum precision.
This is the bezel if you wondered what it is :)
http://cart-products.ifixit.net/cart-pro...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 7,430
