Phone cuts of and comes on at random
i replaced the housing on an iphone x and now the phone restarts at random
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I would suspect something went wrong during the transfer of the flexes and logic board to the new housing. Unfortunately, there are too many variables and not enough info for me to suggest anything more specific.
Try going bare bones to see at what point the logic board does not restart. Just the battery and Charge port connected to the logic board should suffice to boot into iTunes. If that is stable, then keep adding flexes until the phone fails (always disconnect the battery first!). If a minimum setup still fails, try a replacement charge port. Otherwise, you have a logic board issue.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 33
