メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Remove camera lens ring - iPhone 6
So I only found the guide for removing the metal rear camera lens ring on the 6S, is it the exact same procedure on the iPhone 6?
Since i remember that on some of the older iPhones the ring is like welded in four different spots and can be very tricky to get off, don’t know if thats how it is on the iPhone 6 though?
So if anybody knows how it is on the iPhone 6 I would appreciate an answer.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
The iPhone 6 lens is glued in. Put some heat on it and work your way around it with a blade.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks, so should I work it from the inside of the phone or from the outside? If from the outside then doesn't it leave marks in the outer casing around the lens ring?
さんによる
@gadgetuser warm up the housing area and push the glass out from the inside. Clean the shards if present, apply the new glass and warm up a bit again and you should be fine.
さんによる
コメントを追加
it`s the same as 6s, if you want the whole lens off including the metal ring then remove the rear camera and black sponge, pull the metal bracket out from the inside with pliers and the outer lens and ring will come out as one.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes exactly, i want to replace the whole metallic ring and the glass at the same time.
But i know that some iPhone models have spot welded the lens ring in 4 different locations on the inside, so its very hard to remove the ring without damaging the casing.
Don't know if the iPhone 6 is one of those iPhone models which has the ring welded though?
EDIT: Oh boy, it seems that the iPhone 6 is actually one of those models which has its camera lens ring spot welded, this can be a very hard project.
Also it has a square metal bracket on the inside of the camera housing.
This bracket will most likely get so damaged that it can't be used again, and these brackets are not included when you buy new lens rings as far as i´m aware? I haven't seen them for sale either.
I wonder if the bracket is a crucial part, or if the camera and lens ring can be held in place without the bracket? At least the camera seems to be held down by the metal plate that goes on top of the camera, but I suspect that the lens ring is attached to the bracket?
さんによる
コメントを追加
回答を追加する
Jon Smith さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 273
