メインコンテンツにスキップ
Repair guides and support for motorcycles manufactured by Yamaha Motor Company.
Fuel flows out a rubber black hose when running
When bike is running fuel flows out of a black rubber hose cut on an angle.bike runs great.hose goes to right side of carburetor.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Sounds like a leaking fuel hose, I would replace it. Does it have clamps there it attaches to the carb and fuel tank?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hoses tent to break due to vibration and ageing, if you can see it, it would be easy to replace, you don’t specify exact model, but Yamaha usually has special hoses you have to replace with (90 degree, or specific distances), buying an exact replacement is the easiest way of replacing, but a normal hose cut to the distance could be used too if it is not so bent that blocks the fuel flow... Up to you to decide, they used to be cheap at Yamaha…
Also hoses tent to have pressure clips on each side, please confirm the fuel comes from a broken hose, and not from a missing clip on one of the sides.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
2007 Vino Yamaha.hose is in good shape the hose is an overflow hose but why is it overflowing.checked float it works fine
さんによる
コメントを追加
回答を追加する
Glenn Patrick さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 327
