メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1695回答 すべてを表示
My ps4 doesn't turn on and has a solid blue light. What can I do?
My PS4 suddenly stopped working when I tried to turn it on. None of the buttons on the console work so I can’’t even eject the disc. I have tried unplugging it multiple times and leaving it unplugged for weeks in a row. Can you help me please?
Thanks so much!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Since you have tried unplugging the device lets try other options. If possible, try replacing the power cable with one from a any other PS4 or PS3 and see if the issue persists when turning the console on. Just to make it sure that your power cable is ok.
See if the hard drive is seated properly and isn't damaged to fix the blue light of death
  1. Turn off your PS4 completely by holding the power button for at least 7 seconds
  2. Once the power indicator has completely shut off, remove the power cable, then all the other cables from your PS4
  3. Slide off the hard disk drive bay cover and check if the internal hard drive is seated properly
  4. If possible, unscrew the one screw that is holding the hard drive in place and re-seat it back into its slot.
  5. Once you've checked or reseated the drive, put the hard drive bay cover back on, plug all the cables back in and see if the problem persists when turning the console on
  6. If possible, check whether the hard drive itself works by setting it into another PS4 and turning it on.
Please try this and get back with status….
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Have you had any luck fixing this? Mine is the same and I can't find answers
さんによる
@jswain1809 please describe your issue.
さんによる
コメントを追加
回答を追加する
Joe さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 11
今までの合計 1,392
