Why would the motor on my fam get hot an automatically stop working
Why fan motor gets hot an stops working
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @gurlygurl4658 ,
Does it get hot and stop on all 3 of the speed settings?
I don’t know how your particular fan is wired but if it only does it on one speed setting it may be that there is a faulty capacitor connected to the switch for that one speed which may allow extra current to flow through one of the fan motor windings making it get hot.
In a lot of electrical motors there is an integrated thermal switch in the motor itself, which operates to stop the current supply to the motor, if it gets too hot, preventing it from burning out. Once the motor cools down the switch releases and the motor can be started again, only to go through the same cycle if the problem is still there.
If it occurs on all 3 speeds, then perhaps the main run winding has gone faulty and is allowing extra current to flow making the motor get hot.
Are the air intake slots around the fan motor housing clean and free from dust etc? If not, this may impede the flow of draft air through the motor, preventing the heat from leaving the motor, which helps it to keep cool. Just a thought.
Here’s a link to the ifixit How to Replace the Fan Blade Assembly on the Utilitech SFC-1 500B 20 " High Velocity Floor Fan guide, which may be of some help to gain access to the fan motor.
このアンサーは役に立ちましたか?
These fans are cheaply built and very poorly designed , and are a BURN HAZARD. The fan shaft is mounted with NO SEALED BALL BEARINGS so the shaft and housing get extremely hot with the stock SLEEVE BEARINGS. If it has been running for a while and you happen to touch the rear housing , YOU WILL BE BURNED. This fan will run for a limited time as well because of it's VERY POOR design. I would venture to sat these fans are fire hazards....My solution was to disassemble the motor housing and pack high temp lithium grease (650 F drip temp) on both ends of shaft in the sleeve bearings, reassemble, seems to help considerably..
このアンサーは役に立ちましたか?
Thank u so much!! I'll for sure never use another one again!
THIS IS EXACTLY THE FAN I HAVE and it could have started a fire. i found this by googling it.
i’m glad i was home
Yes I am glad I read this too and will not be using it anymore. It shut off which I am grateful it did.
過去 24時間: 5
過去 7 日: 11
過去 30 日: 53
今までの合計 7,132
2 件のコメント
My fan just stopped working what’s wrong with it? My motor was hot but not it’s cooled down and still doesn’t work
Jennifer さんによる
Same problem with mine and it’s only two months old. With very little use ,,,,I’ll never buy another one.
Scott Phelps さんによる
