メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Problems with battery calibration
I just replaced the battery on my grandparents iphone 5, but when going to calibrate the battery i found the percentage to at times not move, go down in big chunks and even go up at times. I am struggling to get it to die, and ive tried everything. Any tips?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Was there any power running through the device when you disconnected the original battery?
It’s always worth double checking the connector to make sure it is sitting down correctly, and ofc use an Mfi cable.
If that all checks out then you could have received a faulty battery, if this is the case there should be a warranty and you should be able to get it replaced.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hey thanks for the response, that all did actually check out, i even opened it back up to ensure everything was sitting correctly. Over the course of the night and day it has been fluctuating between the 5-10% battery, seeming to go on forever no matter what I do to drain the battery. I think i am going to attempt to keep it draining, and then eventually when it dies recharge it and go from there. If it still is acting weird then ill probably send it back. If u think of any other tips while i still have it let me know!
さんによる
コメントを追加
回答を追加する
Ck Perrins さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 54
