メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
914回答 すべてを表示
White screen after replacement, but differently.
I have gotten the famous white screen after replacing the screen, but this time it's a bit different. The screen only turns on when iOS boots up, and never shows the apple logo at all. I'm completely stumped by it because the original screen works perfectly well, it's just in horrible shape. The replacement worked fine when I first installed it, and nothing I've done, not even a restore, will seem to fix this issue. I've even tried the power+vol up+home combination and got absolutely nothing. I'm worried I'll have to refund the screen. If anyone has a solution to this I would appreciate it rather greatly.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Did you try another new screen already?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
@douglasvinicio I haven't had the money to order another one, so no. I just have the replacement I already purchased and the original
さんによる
In base of my experience if your original one is working,your motherboard and FPC connectors are fully functional. So i would assume that is just buy and install a new screen to solve your problem.
さんによる
コメントを追加
Sounds like the screen may be faulty? Get the manufacturer to replace it and see if that fixes it :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@ran9aa I will give that a go.
さんによる
コメントを追加
回答を追加する
SolarisTheBat さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 47
