メインコンテンツにスキップ
The Nextbook Ares 11 NXA116QC164 is an Android tablet with an 11.6-inch display released in 2015.
4回答 すべてを表示
締切られた回答
Having issues with using the touchscreen.
I bought a Nextbook NXA116QC164, android operating system used. When you use the keyboard it works relatively fine. A glitch here or there but nothing big. The problem I’m having with the device is when I disconnect the keyboard(or even when it is connected but I just want to use the touchscreen) that when I click on an app, or even the back button and open application screens it opens the app or presses the button on the opposite side of the screen. See pictures below.
I have tried system updates but it says it is up to date, and did all updates in the play store(though I was sure none of them were the issue). That didn’t work. So I set the device back to factory settings, and the issue persisted. Even turning the screen doesn’t fix anything, the issue continues to persists no matter how the screen is rotated. I tried checking YouTube and google for possible fixes but the only thing I could find with the same issue was an android phone. They had typed something into the phone as though they were going to call someone which brought them to where to update the firmware and something else I can’t quite remember. But I can’t seem to find a path to that same area on this device.
When I check it for android updates it keeps telling me that it’s up to date. Running version 5.0. I’ve looked through other settings and can’t find any that seem like they would or could fix the issue I am having.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Maybe a bad touch controller?
さんによる
コメントを追加
1 件の回答
If your touchscreen is not responding properly, it may need to be calibrated. Touch-screen calibration can be done in your system’s Settings.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I can't find a way to try to calibrate the touchscreen under any of Systems settings.
さんによる
how do i do this with out using my touch screen???????
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 389
