Bluetooth Antenna not working WiFi works
My Bluetooth is not working on my iPhone 6S Plus. What is the difference between the "Top Left Wi-Fi Antenna" and the "Wi-Fi/Bluetooth Antenna?"
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I suspect its most likely a software issue. Go to Settings - General - Reset - Reset Network settings. You will loose any saved Wifi Networks but this may fix your issue. Also check to make sure you're fully up to date. My last step before trying hardware would be a full iTunes restore. It could be the Wifi/Bluetooth Antenna iPhone 6s Plus Wi-Fi/Bluetooth Antenna.
このアンサーは役に立ちましたか?
I did the network delete... I ordered the antenna. Thanks
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 723
