メインコンテンツにスキップ
統合ディスプレイを持たない一般的な据え付けのコンピューターです。
1411回答 すべてを表示
Vizio CA24 stuck on PC Off when booting.
So I recently purchased a secondhand Vizio CA24 All in One Desktop. It was missing a hard drive, WiFi card, and ram which I supplied, yesterday I had it running windows but this morning it gave me a message saying PC off in the top right of the display, I took everything out of the computer and put it back in, but it still refuses to work! Any Ideas? Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Hi Jon,
Let me get this straight. I'm assuming you installed all the missing parts and then installed Windows and it booted up fine. Next day itwould not boot up>
Also
Specifically which model of Vizio CA24 is it?
What happens when you press the power button?
Do any lights come on?
Can you hear anything?
Can you get into the BIOS? Usually one of the following keys - F1, F2 orDel.
Did you check that all the cables are correctly connected?
When you took everything out of the computer were you careful to discharge any static?
Let us know.
さんによる
PSU failure? Fried chip? Imcompatible RAM (Since it's an OEM PC)
さんによる
コメントを追加
1 件の回答
選択されたソリューション
This is a well-known problem with the Vizio CA24 computer. Since it seems to be a manufacturing defect unique to the Vizio CA24, your best bet may be to contact Visio customer support directly.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jon The Otaku さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 775
