Cut electrical wire cord for A1243
I need to know how to replace the cable or repair it.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If it is an USB cable that was cut then you should open your keyboard and re-solder a new cable to the PCB. Please mind to properly connect polarity of the USB power supply and Data cables. It will be 4 wires + ground so if you are handy with soldering iron then you should handle with it.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 9
過去 30 日: 37
今までの合計 1,163
