メインコンテンツにスキップ
2012年11月2日に発売されたiPadの第四世代です。Wi-Fi, CDMAもしくはGSM モデルがあり、16、32、64GBの容量オプションがあります。
408回答 すべてを表示
My iPad charging situation is very hard!
I have this iPad 4 since almost 2015. It has face a lot of problems with charging and a new one is here!!
Sometimes it shows that the “accessory may not be supported “ or it does not charge unless I put it on a certain angle. I changed the cable and the charger, I cleaned the charging port and nothing happened !
after buying a new usb cable it started charging
but again, it started to show the “not charging” thing again but in fact it charges despite the fact that it’s showing that it's not charging
but the charging is EXTREMELY SLOW, the voltage and the energy of the charger and the cable are just perfect to the ipad needs but it barely charges 1% in an hour !!!
I’m really confused and I need advice please???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If the cable and the charger are both brand new, then the problem may be your battery. As a battery ages, it loses its ability to charge and maintain it’s charge. If your battery is 4 years old (you’ve had it since 2015), then it’s probably losing it’s ability to function efficiently.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Siham Daher さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 60
