メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
iPhone 5s battery stuck at 100% after u2 replacement & q2 jumper
Hello,
i had a family member's iphone 5s that has been used with a bad charger for a long time. The phone would not charge/start if battery was completely dead, and when a full or partially charged battery was placed,the phone would start and accept charge but would discharge quickly after that on its own.
So i ordered a new U2 IC chip and replaced it.
U2 replacement worked fine and the phone would start with a charged battery BUT would not detect the charging cable at all. I think in the process i chiped/damaged the Q2 chip.
So i removed the old Q2 chip and put a jumper in the 3 contact points.
Now phone boots up normally and it detects the cable and charges up fine.
The problem is the battery level reports 100% all the time until it actually runs low after hours(lets say the true percentage is 15%) and starts counting backwards from 99% down to 1% and shuts down.
If I plug the charger in, lets say at 4% ,the percentage will normally start going up until it reaches 100% and stays there, until low-battery of course.
What could be the problem? Could it be a bad q2 jumper? I luck the microscope to see if all 3 points are connected ok, but phone works and charges so I guess they are fine...
Could it be a battery problem or maybe some u2 contact points that haven’t been soldered ok?
What part of the phone is actually responsible for measuring the battery percentage?
Notes: The battery I used was a completly new one.
I put a youtube video to play(and test the battery) and played normally for about 5 hours until it shutdown.Seems normal battery life to me.
I am in NO way professional but i like DIY stuff.I only have a cheap hot air gun and a cheap soldering iron but i luck the microscope for precision.
Thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
That is the problem of SWI line see resistance near battery connector might be open.This SWI line is connected to Tigris then CPU.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ermm, as I said before I am inexperienced with this kind of stuff, might I ask for a more fool proof explanation? I don’t know what or where that SWI line is exactly on the pcb to check it. Maybe a picture?
さんによる
コメントを追加
回答を追加する
Konstantinos Thanaselos さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 252
