メインコンテンツにスキップ
2.6GHzデュアルコアIntel Core i5プロセッサ(Turbo Boost使用時最大3.2GHz)、3MB共有L3キャッシュ
120回答 すべてを表示
boot manager not showing both ssd drive and bootable pendrive.
i was previously having 128GB SSD, bought a new SSD (500GB) and fixed into the Macbook pro.
i also made a bootable USB to reinstall my OS X Yosemite
when i power the Macbook and i press the the option key i only get to see the Recovery Disk, i can’t see both the bootable pendrive and the SSD in the startup manager.
The interestion part is when i boot into the recovery and access the disk utility there, i see all drives… i have formatted the drives there but still.
kindly help me out with a possible fix.
thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I suspect the USB drives was not reformatted so its still using FAT32 or exFAT and your Mac won’t boot from that kind of format it needs GUID. Go back into Disk Utility and compare your formats between the drives.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
what i realized is that when i use CMD on windows to convert the pendrive to GPT, the TRansmac reformats it to MBR.
Secondly why is the SSD not showing in the startup manager?
Thanks
さんによる
Again, the format of the file system, is not correct! Reformat it using MacOS Disk Utilities to set it up correctly >> GUID >> Journaled File system (HFS+). Thats why you can't see it as a bootable drive.
さんによる
コメントを追加
回答を追加する
Wilson Fafa さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 379
